Runtal Baseboard: Radiant or Convective?
Scott_V
Scott_V Member Posts: 1
I'm deciding between Runtal UF baseboard (with the fins) and Runtal Wall Panel (also with fins). In certain rooms, baseboard would be more desirable but would be partially blocked by a piano, book case, a few chairs/tables etc....typical living room furniture (No sofa). Runtal's website says their UF baseboard radiators are both radiant and convective. Should I believe them?
Background: I've been told numerous times over the years that RADIANT heating is extremely inefficient when blocked by furniture. If Runtal falls into this category then I would instead go with one of their rectangular wall panels, although less desirable from a design perspective for our tastes.
I'm hoping this question launches a robust debate on convection vs radiant and the effects of furniture on their efficiencies.
  • jumper
    jumper Member Posts: 2,539
    doesn't matter in some ways
    Radiant makes you feel warm. Convection under windows keeps you from feeling cold. Aren't you glad you asked?
  • Jean-David Beyer
    If it is a real piano (one with strings in it), you do not want a heat source under it or even too near it. You would be better off heating a room with a real piano in it with a radiant panel setup either on the walls or the ceiling. And use outdoor reset too. And a constant humidity setup. Pianos HATE temperature changes, especially short-term ones such as a week or faster. And they hate humidity changes as well.
    If you have an electronic, digital, etc., you can ignore everything I just said.
  • Tim_Hodgson
    Tim_Hodgson Member Posts: 60
    Both
    Nuff said.
    Tim
