wall furnace flame recirculation
j1000
Member Posts: 2
in Gas Heating
I have an older double sided gas wall furnace. The local furnace guy wrote up a problem- my wall unit has flame recirculation - what does he mean and how to fix
heater
Does he mean flame roll-out which could be caused by a blocked, damaged or incorrectly installed flue, does the heater have a fan? could the heat exchanger be cracked ? which would require replacement of heaterThere was an error rendering this rich post.
flame recirculation
That has got to be one of the poorest definitions of a problem I have heard? Sounds like he really doesn't know. Maybe its flame fibulation? Or flame resonance? Don't know what any of those mean either. Obviously he didn't do a combusion test!0 -
flame ?
What was your complaint that brought the repair guy to you? Flame rectification?0 -
I have no idea what he meant - never heard of such a thing. I think maybe trying to get me to buy new unit.
the unit is pretty old but still works well - no sticky gas valve, no pilot problems, heat exchangers are fine - solid working unit, just old
I had a couple guys from a different furnace shop stop by and they started up unit and ran without incident. they never heard the term either.
i hope it is not an intermittent problem.....I am just trying to follow up in abundance of caution
FYI - it was part of an inspection0 -
wall furnace
Call the company that supplies your gas In a lot of areas they will check your heater free of charge, and I always recommend a good CO detector in all roomsThere was an error rendering this rich post.
Perhaps the inspector
meant that products of combustion were being "recirculated" back into the room. Was this a home inspector? What did he advise you to do? Did he leave the unit shut off?0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 163 Indoor-Air Quality
- 71 Pipe Deterioration
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
