snowmelt system
Paul S_3
Member Posts: 1,288
hey everyone.....i will be doing a snow melt system for a 40' x 20' driveway....and a 20' x 4' walkway along with the stoop at the front entrance.....are they any design manuals for this...pipe size , loop lengths water temp,controls...etc....??....and customer would like to use existing Navien combi boiler with heat exchanger for this application or would it be better with its own boiler?? thanks PAUL S
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
347-692-4777
ASMHVACNYC.COM
Snow melt
Paul,
The attached manual has great design info.
You are going to face some challenges with the Navien option.
When snowmelt systems fire up they will take all the energy you throw at it.
If you connect to a heating system you have to limit how much it can take.
The tekmar 667 is expensive but works well in these situations.
Personally, I would use a triangle tube boiler for the snowmelt and not use a heat exchanger at all.
Albert Einstein0 -
snowmelt system
so you recommend using its own boiler....if thats not possible at all then that Tekmar 667 would solve problem ? paul sASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
667
The 667 can be set to limit the difference between the supply and return delta t on the snowmelt. You can effectively limit the amount of energy the snowmelt can use.
Albert Einstein0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 960 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
