snowmelt system
hey everyone.....i will be doing a snow melt system for a 40' x 20' driveway....and a 20' x 4' walkway along with the stoop at the front entrance.....are they any design manuals for this...pipe size , loop lengths water temp,controls...etc....??....and customer would like to use existing Navien combi boiler with heat exchanger for this application or would it be better with its own boiler?? thanks PAUL S
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
  • Zman
    Zman Posts: 7,614
    Snow melt
    Paul,
    The attached manual has great design info.
    You are going to face some challenges with the Navien option.
    When snowmelt systems fire up they will take all the energy you throw at it.
    If you connect to a heating system you have to limit how much it can take.
    The tekmar 667 is expensive but works well in these situations.
    Personally, I would use a triangle tube boiler for the snowmelt and not use a heat exchanger at all.
    Carl
    Albert Einstein
  • Paul S_3
    Paul S_3 Posts: 1,299
    snowmelt system
    so you recommend using its own boiler....if thats not possible at all then that Tekmar 667 would solve problem ? paul s
    347-692-4777
    ASMHVACNYC.COM
  • Zman
    Zman Posts: 7,614
    667
    The 667 can be set to limit the difference between the supply and return delta t on the snowmelt. You can effectively limit the amount of energy the snowmelt can use.
    Carl
    Albert Einstein
