Need a t-stat recommendation
Marc K.
Marc K. Member Posts: 15
I have a customer with a radiant slab. Due to the homeowner's request, the previous installer installed a room sensor with a remote setpoint control (Goldline SP-32.  Due to wide temperature swings (due to passive solar), my customer is now looking for a remote thermostat with both a room sensor and a slab sensor.  Looking for recommendations.  The t-stat operates a honeywell V8043 zone valve.
Thanks for any help.
  • Zman
    Zman Member Posts: 7,611
    Tekmar
    Tekmar makes t-stats that will do what you are asking for.
    Is your system using outdoor reset? What are you water temps?
    Carl
    Albert Einstein
  • kcopp
    kcopp Member Posts: 4,606
    I second the tekmar....
    pretty simple.
