Need a t-stat recommendation
Marc K.
Member Posts: 15
I have a customer with a radiant slab. Due to the homeowner's request, the previous installer installed a room sensor with a remote setpoint control (Goldline SP-32. Due to wide temperature swings (due to passive solar), my customer is now looking for a remote thermostat with both a room sensor and a slab sensor. Looking for recommendations. The t-stat operates a honeywell V8043 zone valve.
Thanks for any help.
Tekmar
Tekmar makes t-stats that will do what you are asking for.
Is your system using outdoor reset? What are you water temps?
Albert Einstein0 -
I second the tekmar....
pretty simple.0
- 119 Chimneys & Flues
- 114 Geothermal
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
