Main Steam Trap
SunnyTom
Member Posts: 1
Main steam trap on main return before the condensate pump.
Any ideas about servicing or a replacement?
1 pipe steam system
1 pipe steam system
Going with gravity
If you could modify everything to be gravity-fed, you would be much better off, than with a condensate tank, and master trap. Then there would be no mechanical components to require maintenance.
The only systems requiring condensate tanks/pumps would be those spread out over several separate buildings, served by 1 boiler.--NBC0 -
That's not the usual Webster trap
Is this part of a larger system that serves several buildings from a single boiler or single set of boilers?All Steamed Up, Inc.
Consulting0
- 87K THE MAIN WALL
- 112 Chimneys & Flues
- 106 Geothermal
- 979 Plumbing
- 387 Solar
