Main Steam Trap
Main steam trap on main return before the condensate pump.
Any ideas about servicing or a replacement?
1 pipe steam system
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,578
    Going with gravity
    If you could modify everything to be gravity-fed, you would be much better off, than with a condensate tank, and master trap. Then there would be no mechanical components to require maintenance.
    The only systems requiring condensate tanks/pumps would be those spread out over several separate buildings, served by 1 boiler.--NBC
    Steamhead Member Posts: 18,200
    That's not the usual Webster trap
    Is this part of a larger system that serves several buildings from a single boiler or single set of boilers?
    Consulting
