W/M GV-90+
Roland_18
Member Posts: 147
Hi All,
Came across this Weil-Mclain product. Seems to be a cast iron/stainless steel hybrid, high eff.(91+) boiler. Any experiance with this?
<a href="http://www.weil-mclain.com/en/assets/pdf/gv90_plus_Brochure.pdf">http://www.weil-mclain.com/en/assets/pdf/gv90_plus_Brochure.pdf</a>
Thanks,Roland................
It is the old Weil-McLain
GV series Gold Boilers with a heat reclaimer attached for condensing. Much the same thing Burnham did a while back with the Revolution Series II.
The same controls and operation as the Gold.0 -
90% AFUE
It's for people who can't or won't understand P/S and modulation. If Weil was my choice,I'd go with the 97To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
GV-90+
I agree that nothing can beat a properly designed and installed mod/con.
Looking at the I/O manual, it shows that the GV-90+3 and 4 can be installed without P/S piping while the larger 5 and 6 need to be installed P/S. Diverter T systems may or may not work with the provided system pump.
Also, outdoor reset is offered as a plug and play option provide that the boiler temp not go below 140*F.
I don't work for W/M and have no financial interest. It just looked to me as a possible alternative to a full-on mod/con system.
Roland............0 -
Dollars and sense
I think the GV 90+ has its place on the market. It makes sense on baseboard systems, it's rather small btu load and its proven reliability make it good for many applications. Paired with a good condensing on demand helps your bottom line since the boiler is economical. The draw back is I forgot how heavy these cast iron boilers are. I do feel getting 91-2% all the time whenever it runs is good, especially when you subtract all the possible service calls we ALL get with mod cons.Tom
Montpelier Vt0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 55 Water Quality
- 49 Industry Classes
