Mark Franks
Zman
Member Posts: 7,611
As much as I love my Thursday new letter. this one is simply not true.
<a href="http://www.earthtechling.com/2013/05/new-york-city-could-turn-to-geothermal-heating/">http://www.earthtechling.com/2013/05/new-york-city-could-turn-to-geothermal-heating/</a>
Henry Gifford does a great job explaining this one <a href="http://www.greenbuildingadvisor.com/blogs/dept/green-building-blog/ground-source-heat-pumps-don-t-save-energy">http://www.greenbuildingadvisor.com/blogs/dept/green-building-blog/ground-source-heat-pumps-don-t-save-energy</a>
Carl
Carl
Albert Einstein
Albert Einstein
Tough One
Let's start with the clear factual error: the earth's core temperature has absolutely nothing to do with the suitability of an area for geo-exchange.
Geo-exchange is not the universal solution many proponents claim; nor is it the scam which opponents sometimes make it out to be. It works best when annual heating and cooling loads are *roughly* balanced (say within a 2:1 range) and when soil moisture is high. Payback over a modern ASHP can take quite awhile depending on the local climate. Ground loop installation costs -- especially on existing sites -- can be prohibitive. Depending on the source of electricity, it can produce less (or more) carbon impact than burning natural gas will.
When correctly applied (sometimes in a hybrid system with GSHP plus a high efficiency boiler) and competently installed and managed it can produce excellent results.0 -
COP
What is upper limit on COP of ASHP,particularly mini split? I see this being the eventual "winner"To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
Facts
My point is that their is not a correct fact in the article. The heat pumps run on electricity which is produced in a fossil fuel burning power plant. As Henry points out the net efficiency and carbon footprint doesn't change. A 3 COP from a 30% efficient power source is no different than a 90% efficient boiler. A 3 COP running off PV panels is a different matter.
CArl"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
instead of a loop field
This company uses a fence as the loop field. Clever idea.
A GSHP heat pump is really moving solar energy. The energy from the ground to provide heating is from the sun.
I suppose you could make an argument that the coal is also a result of solar energy, from vegetation that grew 400 million years ago.
A heat pump powered by PV modules would be a nice, but currently expensive, option.
http://www.hautec.co.uk/#fenceBob "hot rod" Rohr
Living the hydronic dream0
- 110 Chimneys & Flues
- 981 Plumbing
- 387 Solar
- 17 Recall Announcements
