Plumbers putty or silicone?
ChrisJ
ChrisJ Member Posts: 16,758
I'm getting ready to install the new kitchen sink and being this is the first time doing this I'm trying to get prepared and learn all I can before diving in.
I used plumbers putty on the basket strainers and now I've got mixed info on what to use when mounting the sink to the counter.
Another thing I'm unsure of is the faucet is a single hole Delta which has a stainless cover that fits over a plastic spacer and I think it comes with a rubber gasket. I've been told in the past to throw rubber gaskets out and use putty when mounting a faucet?
All opinions and comments are welcome as always.
  • Boiler Talk
    Boiler Talk Member Posts: 143
    Silicone
    I'm not a plumber but of the two sinks I tried the putty gave me leaks.  Use Silicone and plenty of it.  Good luck.  It's not hard to remove, but takes time to cure.
  • ChrisJ
    Leaks?
    Thank you for your response.
    I'm assuming you are referring to using silicone to seal the sink to the counter and not the basket strainers?
  • Sam81
    Sam81 Member Posts: 37
    Sink installation
    Use silconized caulk to install the sink enough the it should squeeze out when's tightening the clips, and silicon between the strainer and sink and wiped then with a dry towel and ready to use
  • jonny88
    jonny88 Member Posts: 1,139
    putty
    if using putty on marble make sure you get the right type made especially for marble.clear silicone is good for fitting sink,putty also maybe its a choice of preference.i usually use putty and always use putty on strainer(easier to remove in the future.)
  • Boiler Talk
    Silicone it all
    Nope, I meant the whole thing.  Good luck.
  • jumper
    jumper Member Posts: 2,460
    anybody try liquid gasket ?
    I haven't but I intend to.
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,417
    putty on strainers and silicone on rims
    silicone is NOT for strainers. if it leaks with putty sorry guys you did it wrong. I have been using putty to install basket strainers since I was 6 and it is the right product for the job. That is 36 years of installing with putty. I also use good quality strainers. The one with the zinc nuts should just be left in the box they come in and thrown away.
    cell # 413-841-6726
  • ChrisJ
    edited July 2013
    Yep
    After doing it I have to agree with Mr Garrity.
    Putty on the strainers worked great. On the rim of the sink however, I ended up with small gaps on all 4 corners and you can see the putty.
  • Bob Harper
    Bob Harper Member Posts: 1,112
    putty vs sillycone
    Since the strainer is considered replaceable, use putty. It has worked for generations. Sealing the basin to the counter should be silicone unless expressly forbidden by the counter fabricator. Choose the correct silicone, though. Acid cure silicones are suitable for thin joints where it won't corrode the adjoining materials and acts as an adhesive. Thicker joints >1/16" or so should be a neutral cure silicone which is better at gap filling but not very adhesive. When laid in a thick bed, acid cure silicones tend to skin over without curing the inside. Neutral cure will cure throughout quickly. Make sure the caulk is NSF approved. If you really hate silicones like me, you might consider a polyurethane caulk instead.
    HTH
