Propane as fuel
fishpimp
Member Posts: 2
Howdy,
My wife and I have purchased 20 acres in rural Island Co. We will start building in one year. We will not have access to natural gas. I plan to install radiant heating and would like to use propane (also for cooking and hot water). Are there boilers that can use propane?
The home will be less than 2,000 square feet. Will I need a large fuel tank?
Thanks
Thanks
You bet
Most natural gas models are available in propane versions. For radiant heating, high efficiency units work very well as they love the low water temps.
If you insulate well and install good windows, a 500 gallon tank should be plenty.
This site has tons of good info.
Albert Einstein0 -
LPG
Some areas have better LPG distribution than LP.0 -
Thanks
Good info.
Thanks for the help.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 986 Plumbing
- 389 Solar
