E.D.R. of convector
ben_18
Member Posts: 70
I am trying to figure out if the boiler is the right size for the house. There are a couple of convectors in the system. They are like the ones found on page 101 in "We've got steam heat." What is the E.D.R. per inch of these convectors?
That's a generic picture
Lots of manufacturers made convectors that looked like that and the rating would depend on which one you have. Pictures would help.Retired and loving it.0 -
Heres the picture
The convectors are built into the wall and can't be opened up. I guess the height of it could be measured buy putting a tape measure in through the top and bottom if that would help. Attached is a picture of it.There was an error rendering this rich post.
Ouch.
These always shrug their muscles and give one the hairy eyeball. Without knowing what sort of element is hiding back there it's just guessing.
Anyone else want to wade in here?Retired and loving it.0 -
Can we?
Can we consider that a hidden radiator Dan?! Hehe, that grill looks like it can be removed. Similarly, the opening at the floor seems somewhat accessible. I would remove the grill, measure the length/depth of element, then probe from the bottom and top to see if you can get an idea of the height. I would do this on 1 radiator and use as a template, so to speak, for the rest.0 -
You would, Danny.
But I don't know our guest's abilities when it comes to probing into walls. A lot went into the design of those things.Retired and loving it.0 -
You would, Danny.
I would take
the cover off but it is covered by sheet rock and I don't want to ruin the paint.
I guess the bottom could be taken off. I have taken off the cover and looked inside. Here's a picture-There was an error rendering this rich post.
Here are two sources
which you can find right here in the Library. Yes, it really does pay to wander off the Wall:
http://www.heatinghelp.com/article/158/Radiators/1269/Herman-Nelson-Invisible-Radiators
http://www.heatinghelp.com/article/158/Radiators/1280/Trane-Heat-Cabinets
Now, how did I know these could be found there? ;-)All Steamed Up, Inc.
Consulting0 -
Looks good
Thanks! I have my work cut out for me.There was an error rendering this rich post.
While you're at it
See if you can slip a vacuum hose down there and clean those fins.0
- 87.1K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
