Check valve position
hrlevy
hrlevy Member Posts: 19
I am installing a laundry tub pump for washing machine to drain into. I was wondering if the check valve can be installed horizontally or does it need to put vertically. All the instructions say is to install near to pump.
thank you.
  • jonny88
    jonny88 Member Posts: 1,139
    check valve
    on a 45 degree is best
    Jamie Hall Member Posts: 26,177
    but if you can't do that
    a regular swing check should -- in my view -- always be installed so that the flow through it is horizontal or upwards -- never downwards.
