Odd combined single pipe in a 2 pipe system
Landy
Landy Member Posts: 7
There is one steam feed in my basement that has a T with a return to my wet return below the steam feed to a radiator. Is this common? Is this OK? I have not been able to identify a specific radiator it feeds, so could it have a different purpose?
  • JStar
    JStar Member Posts: 2,752
    Steam
    Could just be a riser drip to compensate for the inability to properly pitch the run out. Shouldn't be an issue.
    Steamhead Member Posts: 18,211
    Maybe
    there is an air vent up there, which was hidden when the ceiling was installed?
    Consulting
