weird monoflo?
Paul S_3
Member Posts: 1,291
Hey everyone....has anyone ran into a monoflo system where the installer didn't use diverter tees...they used reducer tees like in the pic I posted below...?. ...the reason I'm asking this is because I have to add a radiator to the system....the radiator will go on the floor directly above the main. .if I use the same setup will it work? They used a 1 1/4 by 3/4 tee..
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
347-692-4777
ASMHVACNYC.COM
not so wierd....
Just looks like pre-monoflow fittings, smaller diameter pipe between the reducers forces some of the flow into the loop. I would guess you could do it the same way, but I would pipe in a globe valve in the main run in case you need to throttle, to get a little more flow into the radiator.
What was the return temp by the time you get back to the boiler?There was an error rendering this rich post.
between
The two tees is 3/4 pipe....can I pipe my tees in and connect with 3/4 copper and have Q&A/4 sweat ball valve to throttle?ASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
ball valves
make rather poor flow control devices. I'd use a globe valve.0 -
Are you saying.....
Between the 2 reducing tees you want to put 2 more tees?
I don't think that will work. You may not get flow thru the branch the the original tees were serving. Or you may need a way to throttle both the original branch and the new branch, or you may not get the propr flow thru one or both.
If I misunderstand please show a sketchThere was an error rendering this rich post.
I have seen a lot of systems like that
just cut in your new radiator and install a couple globe valves {I put one on the main and the branch}0 -
thanks
thank you guys for the input....i cut into the main rethreaded some pipe added the two tee's about the width of the radiator and used a globe valve on the main between the tee's ....works great thanks PAUL SASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
- 167 Indoor-Air Quality
