weird monoflo?
Paul S_3
Paul S_3 Member Posts: 1,297
Hey everyone....has anyone ran into a monoflo system where the installer didn't use diverter tees...they used reducer tees like in the pic I posted below...?. ...the reason I'm asking this is because I have to add a radiator to the system....the radiator will go on the floor directly above the main. .if I use the same setup will it work? They used a 1 1/4 by 3/4 tee..
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
  • STEVEusaPA
    not so wierd....
    Just looks like pre-monoflow fittings, smaller diameter pipe between the reducers forces some of the flow into the loop.  I would guess you could do it the same way, but I would pipe in a globe valve in the main run in case you need to throttle, to get a little more flow into the radiator.
    What was the return temp by the time you get back to the boiler?
  • Paul S_3
    between
    The two tees is 3/4 pipe....can I pipe my tees in and connect with 3/4 copper and have Q&A/4 sweat ball valve to throttle?
    347-692-4777
    ASMHVACNYC.COM
  • SWEI
    SWEI Member Posts: 7,342
    ball valves
    make rather poor flow control devices.  I'd use a globe valve.
  • STEVEusaPA
    Are you saying.....
    Between the 2 reducing tees you want to put 2 more tees?
    I don't think that will work. You may not get flow thru the branch the the original tees were serving. Or you may need a way to throttle both the original branch and the new branch, or you may not get the propr flow thru one or both.
    If I misunderstand please show a sketch
  • heatpro02920
    heatpro02920 Member Posts: 991
    edited March 2013
    I have seen a lot of systems like that
    just cut in your new radiator and install a couple globe valves {I put one on the main and the branch}
  • Paul S_3
    thanks
    thank you guys for the input....i cut into the main rethreaded some pipe added the two tee's about the width of the radiator and used a globe valve on the main between the tee's ....works great thanks PAUL S
    347-692-4777
    ASMHVACNYC.COM
