Normal Height for Gypcrete Pour
Billy_Buck
Member Posts: 5
I figured may be easier to start new thread instead of burying in my previous post. As far as I can see from Maxxon as normal pour with sleepers has the gypcrete level with the top of the sleepers not below the sleepers as it can create a void.
Did I get this right?
Shrinkage
The condition you have is very common. I think it is unavoidable. We normally glue wood floors over gyp. You could use a trowelable glue to fill the gap.
Albert Einstein0 -
2 Inches
The Gypcrete in my house, upstairs is about 2" thick.0
- 109 Chimneys & Flues
- 975 Plumbing
- 386 Solar
- 17 Recall Announcements
