Venting, less better?
Fizz
Fizz Member Posts: 555
Recently replaced Gorton#2 main with Trane vacuum vent at suggestion of old timer, but I removed disc to prevent vacuum.  Result was no different, took about 20-25 min to satisfy thermostat, then duct taped 2 of holes in vent, and heat time reduced to 18-21 minutes.  Pressure remains between 1-2 oz.  How is this possible?
  • ChrisJ
    ChrisJ Member Posts: 17,073
    T-stat
    Is the thermostat being heated by a radiator near the start of that main?  And if so, how are the rooms at the end of the main?  Warm? Freezing?
  • Fizz
    Room with t-stat
    Actually the radiator heating room with t-stat is last on 2nd loop off system riser.  All rads heat as before.
  • ChrisJ
    edited March 2013
    How long
    How long are the mains, what size radiators and what vents are on the radiators? What size is the boiler?
  • Fizz
    Length of mains?
    Don't know length of mains, but radiator EDR is 518 sq ft, there are no vents on rads as system is Richardson, 2 pipe(see prior posts).  Boiler is W-M SGO 6, which we converted to gas last year.  It is rated 654 sf of steam.
  • ChrisJ
    Oh
    I can't help you on that then.  I have zero knowledge on that type of system.
    Sorry.
  • JStar
    JStar Member Posts: 2,752
    Vents
    Time to fill the main, or time to fill the radiators? If the radiator time reduced, it may make sense. Richardson systems only have vents on the return, so you may have forced steam through all of the radiators first, if there are indeed vents on the main.
  • Fizz
    Honest guy
    Thanks for your input, and honesty.  Not having a problem, actually running for shorter time, with no change in heating quality.
    Jamie Hall Member Posts: 26,847
    Vapour systems
    can be a little fussy about venting.  They like to be vented at the ends of the dry returns, rather than the mains.  The mains are usually cleared by crossover traps to the dry returns.
    Your results are interesting -- but if it's an improvement, leave it be!
  • Fizz
    You're right
    Richardson does vent thru dry return, but they have no crossover traps either.  Interesting system, and simple.
  • Dave in QCA
    Dave in QCA Member Posts: 1,806
    Question
    I have played around withe those old Trane main vents.  I have a couple that are float vents as opposed to their Quick Vent, which is a little smaller in size.  The float vent was designed to be used as a vent on the return piping.
    Just one question...   why did you decided to remove the disc?  The ones I had already had the disc removed and I, and a freind both worked hard to try to replicate a workable disc, but were not successfull.  So, I installed a simple swing check instead.  I like vacuum.  My system likes it.  Steam gets around the system faster on next cycle, etc.  Less air to vent if you don't let it back in.
    Dave in Quad Cities, America
    http://grandviewdavenport.com
  • Fizz
    Disc in Trane
    Dave, think you're right.  I removed disc because I don't have a vacuum gauge, and my low pressure gauge went 1/3 of way past 0 on face, so rather than break it I removed disc and close-off 2 of vent holes which slows down air return to system which I think makes system heat quicker as my heat satisfaction time is 18-20 min vs 20-25 min.
  • ChrisJ
    Don't know
    I'd rather vacuum and a broke gauge my self than fight the air every time on a system designed for vacuum.
  • Fizz
    Vacuum
    My intention is to replace lp gauge with vacuum gauge and see what happens.
  • Fizz
    Vacuum
