Unfamiliar with this setup
Quigley
Member Posts: 3
I inspected a home this morning with an unusual boiler setup. The oil unit was converted to gas but still uses a barometric damper instead of a draft hood. Is this O.K. ?
Question two. Someone tied the new boiler into an old boiler and is using them in tandem. Any thoughts.
The Barometeric...
should have been changed out to a double acting type. I just did this this morning. A Field MG-1 and a spill switch.0 -
presume powered burner
kcopp is correct. I don't understand why hoods are mandatory on atmospheric.0 -
furthermore....
you can't have a draft hood on a converted set up. The boiler w/ a conversion burner is not an atmospheric boiler....by all rights it is a fan assisted set up.0 -
i do believe
u can use a double acting draft control on atmospheric.0 -
yes you can.
this is what should be on a boiler converted to gas from oil... http://www.fieldcontrols.com/m_mg1.php
along w/ this.... http://www.fieldcontrols.com/thermal.php0
