Restoration of my Dunham Air Eliminator!
Ban
Ban Member Posts: 79
I have finished the restoration of my Dunham Air Eliminator 220. Everything is original except for the check-disk, brass plug and stainless steel screws have been updated. I tried to match the color the best I could from what I saw on the metal to be the first and original layer of paint.
Now I have to install it!
Richard Ban
Detroit, Michigan (Dunham 2-pipe vacuum)
  • Dave in QCA
    Dave in QCA Member Posts: 1,806
    Beautiful!!
    Very Nice Job!  The Air Eliminator Looks Great!!
    Dave in Quad Cities, America
    http://grandviewdavenport.com
  • JStar
    JStar Member Posts: 2,752
    Dunham
    I wonder...should this be labeled as NSFW? Looks awesome. You'll get another 100 years out of it now.
  • Ban
    100year
    I know. I was going to use brass fittings but stopped myself at the plug. This stuff can become a bit of an obsession. I had the realization that I will be long gone and this thing will (hopefully) still be working.
    Richard Ban
  • moneypitfeeder
    moneypitfeeder Member Posts: 252
    Really Nice Job!
    Looks great, you really did nice work on that, hope you get many years of use from it!
  • Ban
    Installed!
    I finally re-installed the air eliminator as well as replaced the nearby rotten pipes. It was 60 degrees here yesterday but now we are back to 25 here in Michigan so I will be firing it soon. I have a crossover trap to install which I just got in the mail yesterday. Cross your fingers and hope I obtain a least a couple inches of mercury!
    Richard Ban
  • Dave in QCA
    Looks Like New
    Ban, Nice job!  It should work great!
  • Ban
    It should work great,
    as long as my 90 year old valves, pipes and fittings don't have any leaks under vacuum. That will be next years task [ :) ].
    Richard Ban
