Shark Bite or no Shark Bite
Steve Thompson (Taco)
Member Posts: 204
Fellow Wallies, I request your opinion...
I am one of the unfortunate folks with Poly B in my house and yes, some of the fittings are starting to leak (my plan is to replace with PEX).
What's your opinion of Shark Bite fittings - yea or nay?
Longevity
I don't know.They are rated for 180*.0 -
gatorbite
Lowes sells Gatorbite brand, they're rated @ 250 degs. I've used them on my potable water system on copper to CPVC and such. No issues to date. I wouldn't trust them behind walls or such. The o-rings can only last so long. I think they're rated for 20 or 25 years.
Earl0 -
Poly B
Are you replacing domestic water piping or radiant piping? What brand of PEX are you planning to use for replacement? Are you replacing it all or splicing pieces in?
Rob0 -
No Issues Yet
Been using them since they came into the market with no problems as long as the pipe isn't out of round. Used them on hydronics, including outdoor wood boilers with continuous circulation, and had no issues.
Make sure you use the plastic insert on plastic pipe.Bob Boan
Couple issues...
This may not be a problem for everyone so please disregard if doesn't apply to you.
1- Don't (as Earl already said) use them in walls or places you cant access. I had a customer who had frozen pipes and called me, she said the whole place is in copper but "forgot" about the 3 sharkbite fittings hidden in the wall. I spent 3 hours scratching my fat head as to why my new pipe thawing tool didn't work. Plastic fittings won't allow the circuit to travel!!
2- Antifreeze seems to eat the orings very quickly, so if the system has antifreeze I would avoid them.
In my experience they are great for temporary use, but wouldn't trust the 25 year warranty claim
Just my 2 cents...Tom
Montpelier Vt0 -
buy a crimp tool
and use the fitting designed for the tube, either pex or pb. It may end up being less $$ compared to a bag full of "grip" fittings.Bob "hot rod" Rohr
Not sustainable
I agree with Hot Rod
Crimp system is permanent
We have seen many failures over the years from these fittings
I believe they are made for DIY
make a professional, sustainable installation using crimp system
there are many systems to choose fromThere was an error rendering this rich post.
only place I use shark bite
is for tempory test caps and temporay repair valves. I vote for getting the proper crimp tool as a house full of fittings will add up fast.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
- 119 Chimneys & Flues
- 116 Geothermal
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
