Where can I get push nipples?
eklektech
Member Posts: 6
I have a Smith G200W5 boiler with a Dunkirk block. Does anyone know where I can buy push nipples for that boiler block?
Or does anyone know where I could cross reference that block with others that use the same nipple?
Just for a chuckle, I"ve included a pic of how I fixed my boiler from leaking on the floor.
Thanks
dave
Thanks
dave
Uh...
Have you tried Dunkirk?
Dunkirk homeowner support: 866-847-6656Bob Boan
nipples
do you want to repair that boiler . i would think you would be better off just replacing it . how old is it0 -
Leaking sections
You should probably order new sections as well, as I am sure the faces of the sections into which the push nipples go are corroded as well.
Have you any idea what has caused this-excessive makeup feed water, dry-firing, or sludge in the bottom?--NBC0 -
Uh....
....yes i tried dunkirk. some young woman answered, asked for my zip code and gave me a phone number which i called and the guy that answered said they have all the seals and gaskets. "we aint had nipples in years."0 -
old?
best i can tell, that boiler is close to 40 years old and aside from the broken nipple, i see no reason to replace it. i like to fix things instead of tossing them in the landfill and replacing them. i'm oldschool like that.
I took the boiler out last week, took the right end plate off and after several attempts, milled a nipple which is sealed up just fine. I'm assuming the problem is that from the jostling around, the seal on the next nipple down was broken and now leaking.
I'm not looking for a bunch of commentary on my boiler, I'm just asking if anyone knows where I can get new push nipples. if you don't know, i don't see the need for the blather.
sections
it's odd that although i have had the opportunity to actually see the face of the section, which is, oddly enough, in beautiful condition, that you would speculate on said section.
what i think caused it is a faulty pressure reducing valve that didn't consistently keep the pressure at 12 lbs. I didn't know this until recently and have replaced the valve. and as a co-respondent to the valve, the pressure gauge on the boiler itself, when i emptied the system read '8 lbs.'
once again, any info on the original question would be great.0
- 120 Geothermal
