combo heating system question
JP4120
Member Posts: 4
I have an Energy Kinetics system 2000 about 12 years old and was using my heat pump for a/c only until it died at about 29 years old. Purchase an Amana heat pump (15 SEER) and was advised to use the heat pump for heat and use the system 2000 as aux heat at about 34/35 degrees. Any opinions on this? I guess the system 2000 is more comfortable, but need to factor in oil prices a bit...
That's What...
I'd recommend for our area, but you have to factor in fuel costs and climate for you area.Bob Boan
S/W Pa location
the installer of the heat pump recommended the aux heat (oil fired boiler) to come on around 33/34. I assume heat pump is probably a bit cheaper to run than oil since heating oil is around $3.50/gallon. Not a slam dunk though because system 2000 is pretty efficient.
I was just wondering if anyone had a differing opinion or other rule of thumb to follow.0 -
no rule of thumb needed
http://www.eia.gov/neic/experts/heatcalc.xls will help a lot. Put in the costs of electricity and oil, the efficiency of the EK, and the EER or COP for the heat pump.0 -
numbers look lower than expected for electric
I locked in 7.5 cents per KWT with a PECO competitor for generation charges
so with 7.5 cents and HSPF of 9 = $8.33 per million BTU
fuel oil of $3.69/gallon (last paid) using 85% AFUE (efficiency is per EK2000 - could be exaggerated) - = $30.70 per million BTU
guess thats why I should keep the aux heat (which pulls on the oil at 33/34 degrees, if I set it lower than that the electric coil heat pump emergency heat may kick on..0 -
cost per kWH
Divide the total bill by the usage - those 'additional charges' can add up.0 -
Exactly
The transmission costs can equal the electricity costs and then the seven cents ends up costing you a total of 14 cents per KWH.
Make sure you understand it before you jump.
3PSI gauge0 -
good point...thx
transmission and distribution charges for PECO are about another 7 cents per KWT right now....so need to include that in my comparison.0
- 167 Indoor-Air Quality
