Historic home with radiators
Dexter12
Member Posts: 5
1860 Farmhouse with 18" stone walls in front with addition that was
probably done in early 1900's that is cedar clapboard on
outside,uninsulated walls. Clapboard is in good shape,no cracks or
openings,pretty solid. All the windows were replaced with Anderson last
year (home is in a Historic District) north of Phila Pa
Heated space is 2050 sq ft,
Attic which which is finished but has no radiators is 400 sq ft
Currently has a Peerless WBV-03 Oil Boiler (with a tank less coil in the
Boiler) and a Bradford White Electric Water Heater run parallel with the
boiler, house has cast iron radiators
We are going to convert to gas and I want a boiler with an indirect tank. Also would like to go high efficiency ,mod con
Any suggestions would be appreciated
Thanks
Thanks
Mod Cons
Mod cons will usually work well with existing radiators. Hopefully you can find a contractor in your area that has expertise. I like the Viessmann Vitodens 200 and their VitoCell 300 SS indirect tanks. I use an NTI Trin n Stor, if the Vitocell is over the budget.
When retrofitting a radiator system, we always change the radiator valves to TRV's. The system will perform at highest efficiency when a "Smart" pump (i.e. Grundfos Alpha) is installed on the heating circuit.0 -
Agreed
The Triangle Tube, The Knight WHN and the Utica/Dunkirk at the bottom of the page are good mod/cons that we install and like. I would not use a boiler with a Gianonni heat exchanger unless you have a good servicer that's going to do thorough annual maintenance. Many manufacturers use this heat exchanger, so you need to ask your installer if the boiler they're proposing has it.
The most important thing in the equation is the installer: he's 98% of it. Make sure you get references and pics of his recent installs and post what he's proposing back here for review if you want recommendations.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
