hartford loop height
TomM
install manual says 2" below normal water line.
is that 2" to the top of the close nipple, or to the center of the nipple? i guess the lower the better to avoid hammer, correct?
Thanks!
Thanks!
From Top of close nipple
I just did some reading to see what the manufacturers say about it. Burnham v9 instructions simply say 2-4" from the normal water line. Weil-McLain for the 80 series say 4" from the normal water line to the top of the close nipple connection of the Hartford loop.
So, I would go with a measurement from the top, just to be safe.Dave in Quad Cities, America
http://grandviewdavenport.com0 -
Hartford
or Gifford? I've read Henry's articles on it, but am curious if others here have direct experience with using a Gifford Loop.0
