hartford loop height
install manual says 2" below normal water line.
is that 2" to the top of the close nipple, or to the center of the nipple?  i guess the lower the better to avoid hammer, correct?
Thanks!
  • Dave in QCA
    Dave in QCA Member Posts: 1,806
    From Top of close nipple
    I just did some reading to see what the manufacturers say about it.  Burnham v9 instructions simply say 2-4" from the normal water line.  Weil-McLain for the 80 series say 4" from the normal water line to the top of the close nipple connection of the Hartford loop.
    So, I would go with a measurement from the top, just to be safe.
    Dave in Quad Cities, America
    http://grandviewdavenport.com
  • SWEI
    SWEI Member Posts: 7,348
    Hartford
    or Gifford?  I've read Henry's articles on it, but am curious if others here have direct experience with using a Gifford Loop.
