If our community has helped you, please consider making a contribution to support this website.  Thanks!
flame sensor
                    anthony_24
                    Member Posts: 25
                                  in Gas Heating
                    I have an American Standard Freedom 95 Comfort r furnace.I would like to know if is all right to clean the flame sensor or replace it. If I should replace it would anyone the right part # for it. I tried finding the # on the net but no luck, and my manuals have no #"s.
Thanks in advance for your help and Happy Thanksgiving.
            Why do you want to clean it?
 Are you doing some annual maintenance or are you having a problem. If you want to clean it use a soft piece of Emory cloth and gently clean it off do not remove metal surface.
 Do you have an American Standard Installation and Operations manual? If so part numbers should be in there.
 Find out who the local dealer for American Standard is in your area they will be able to help you.0
            flame sensor
 The issue I have is the unit starts, fires briefly ( about 3 seconds) then shuts down. Tries to start 2 more times then locks out. I found out on the web it was a dirty flame sensor. I figured if it was worth a try to (if possible) clean sensor.
 I also have manual and installation guide and neither have part #'s that I could see.
 Thanks Tim for your help and your great site..
 Happy Thanksgiving0
            Make sure you have a good
 ground, this sounds like it could be a problem with ground. Go ahead and clean the sensor and make sure it is 3/4 to 1" into the flame and 1/4 to 1/2" from the burner face.0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 112 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
