flame sensor
anthony_24
Member Posts: 25
in Gas Heating
I have an American Standard Freedom 95 Comfort r furnace.I would like to know if is all right to clean the flame sensor or replace it. If I should replace it would anyone the right part # for it. I tried finding the # on the net but no luck, and my manuals have no #"s.
Thanks in advance for your help and Happy Thanksgiving.
Why do you want to clean it?
Are you doing some annual maintenance or are you having a problem. If you want to clean it use a soft piece of Emory cloth and gently clean it off do not remove metal surface.
Do you have an American Standard Installation and Operations manual? If so part numbers should be in there.
Find out who the local dealer for American Standard is in your area they will be able to help you.0 -
flame sensor
The issue I have is the unit starts, fires briefly ( about 3 seconds) then shuts down. Tries to start 2 more times then locks out. I found out on the web it was a dirty flame sensor. I figured if it was worth a try to (if possible) clean sensor.
I also have manual and installation guide and neither have part #'s that I could see.
Thanks Tim for your help and your great site..
Happy Thanksgiving0 -
Make sure you have a good
ground, this sounds like it could be a problem with ground. Go ahead and clean the sensor and make sure it is 3/4 to 1" into the flame and 1/4 to 1/2" from the burner face.0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
