Boiler Size ?
sgtmikey
Member Posts: 14
Hi. I am considering switching to gas. I currently have oil/radiant heat in a cape on Long Island. That inground tank is an accident waiting to happen. I converted to radiant heat a few years ago. I had the install specced out by a company in Maine. They provided me with this info based on my report of room size, r values, windows, etc: They gave me a total heatload w/o DHW: 38kBTU's/HR.
The install was plumbed into the existing boiler. Now that I am switching, I have the opportunity to correctly size the boiler. What should I be looking for? The new setup will have a 60 gal indirect hot water tank.
Thanks. Great site, btw.
Firetube HX
I would be looking at a Mod/con boiler. The biggest difference between models is the heat exchanger. There are many posts on here debating which is best. My preference is Triangle Tube. The Prestige 60 looks like a good fit for you. What are your DHW needs? What heats your dhw now?
Albert Einstein0 -
DHW
DHW needs are not great. Just two of us but she likes her baths. DHW is provided by a coil in the boiler right now.0 -
Small world
Just got your contact info from Triangle Tube!To learn more about this professional, click here to visit their ad in Find A Contractor.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
