If our community has helped you, please consider making a contribution to support this website.  Thanks!
Thermocouple
                    Techman
                    Member Posts: 2,143
                                  in Gas Heating
                    I saw on a t'couple a crimp about 1/4" long ,it was 2" back from the pilot assembly. What is the purpose of the crimp?
            Do you mean the little indentation on the copper
 lead? If so that is to insure the inner copel lead inside the copper tube and attached to the cold junction on the thermocoupe does not come loose. If it did the millvolts would not be able to get to the magnet assembly and the system would not work.0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 112 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
