Munchkin v. Elite
dsylv0257
Member Posts: 1
I'm looking to replace my old Munchkin T80 M with the new Elite but can't seem to grasp my head around what the difference is between the two?
Heat exchanger ....
totally different. Munchkin is a Gianonni type... New Elite FT is more like a Triangle tube down fire type0 -
Lots
6:1vs3:1 turndown ratio. Slightly higher efficiency. Controls, condensate trap are all a step up.
The HX while not of fire tube nature like the TT, and the new Knights. It's a lower head hybrid Downfire type with baffles.
Why are you replacing the t80?0 -
Better explanation
I'm guessing the OP is a women in her 50's, just a guess
The answer is, it's better0 -
elite
Change the boiler ONLY if you go to the new fire tube version.
The new ELITE boiler IS a vertical fire tube heat exchanger.0 -
Which elite
Maybe I'm mistaken, but ther is the Elite, Elite plus, and the Elite FT.
The elite has a 6:1 turndown
The elite Plus has a 10:1 turn down. Does not require P/S piping
the elite FT has a fire tube HX. With a 5:1 turndown. Does not require P/S piping.
OP was asking about the Elite.... To many choices one line FT with 10:1 turn down covers it.0 -
Elite FT
The Elite and Elite plus are very similar to the munchkin. Just different controls.
The Elite FT is the same exchanger TT and Lochivar is using. I would go with the FT or better yet, just buy a triangle tube.
Albert Einstein0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
