Munchkin v. Elite
dsylv0257
dsylv0257 Member Posts: 1
I'm looking to replace my old Munchkin T80 M with the new Elite but can't seem to grasp my head around what the difference is between the two?
  • kcopp
    kcopp Member Posts: 4,434
    edited October 2012
    Heat exchanger ....
    totally different. Munchkin is a Gianonni type... New Elite FT is more like a Triangle tube down fire type
  • Gordy
    Gordy Member Posts: 9,546
    edited October 2012
    Lots
    6:1vs3:1 turndown ratio. Slightly higher efficiency. Controls, condensate trap are all a step up.
    The HX while not of fire tube nature like the TT, and the new Knights. It's a lower head hybrid Downfire type with baffles.
    Why are you replacing the t80?
  • HDE
    HDE Member Posts: 225
    Better explanation
    I'm guessing the OP is a women in her 50's, just a guess
    The answer is, it's better
  • Steve Whitbeck
    Steve Whitbeck Member Posts: 669
    elite
    Change the boiler ONLY if you go to the new fire tube version.
    The new ELITE boiler IS a vertical fire tube heat exchanger.
  • Gordy
    Which elite
    Maybe I'm mistaken, but ther is the Elite, Elite plus, and the Elite FT.
    The elite has a 6:1 turndown
    The elite Plus has a 10:1 turn down. Does not require P/S piping
    the elite FT has a fire tube HX. With a 5:1 turndown. Does not require P/S piping.
    OP was asking about the Elite.... To many choices one line FT with 10:1 turn down covers it.
  • Zman
    Zman Member Posts: 7,569
    Elite FT
    The Elite and Elite plus are very similar to the munchkin. Just different controls.
    The Elite FT is the same exchanger TT and Lochivar is using. I would go with the FT or better yet, just buy a triangle tube.
    Carl
    Albert Einstein
