old HYDRONIC UNIT HEATER
hrlevy
Member Posts: 19
I am trying to install an old HYDRONIC UNIT HEATER in my garage. The heater will be hung the ceiling joists. Should the hot supply be connected to the top or the the bottom fitting?? Will it make any difference if I use 3/4 or 1 inch pex ?? The pex will be connected to 3/4inch copper.
thank you
Howard
thank you
Howard
sounds like a Modine heater
boiler supply in the bottom, return on top. How many BTU's? If it is 1" tappings, I would use 1". How are you going to mount your aquastat? Something needs to turn on the blower on temp increase0 -
it's an OLD Fedders
I plan to turn on fan with same relay as the zone pump.0 -
that is way I was taught. Do the opposite of steam. But I never figured out why.0
