old HYDRONIC UNIT HEATER
hrlevy
hrlevy Member Posts: 19
I am trying to install an old HYDRONIC UNIT HEATER in my garage. The heater will be hung the ceiling joists. Should the hot supply be connected to the top or the the bottom fitting?? Will it make any difference if I use 3/4 or 1 inch pex ?? The pex will be connected to 3/4inch copper.
thank you
Howard
  • billtwocase
    billtwocase Member Posts: 2,384
    sounds like a Modine heater
    boiler supply in the bottom, return on top. How many BTU's? If it is 1" tappings, I would use 1". How are you going to mount your aquastat? Something needs to turn on the blower on temp increase
  • hrlevy
    it's an OLD Fedders
    I plan to turn on fan with same relay as the zone pump.
  • jumper
    jumper Member Posts: 2,501
    that is way I was taught. Do the opposite of steam. But I never figured out why.
