Armstrong valves
Mikekeno
Member Posts: 1
I recently purchased a 75 yr old home and it has hot water heat with Armstrong one way t's to provide directional water flow. Does anyone know where I can find some of those ? They're 1" with 3/4 " t . Thanks
Diverting tee?
Are you talking about diverting tee? I do not believe those are still made. B&G make a monoflow tee."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
- 87.8K THE MAIN WALL
- 131 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
