Name That Boiler!!!
susie
in Gas Heating
Can anyone identify any of these boilers, the year they were probably installed and their typical energy efficiency?!?!
I need to prove that I am increasing the efficiency of my rehab by 34% after installing new energy star equipment but I can't unless I know what the originals are...
Thanks!
Thanks!
Look on the
rating plates for the Make, Model Number and Serial numbers. Also look for Input in BTU's and Output in BTU's.
Has a heat loss been done on these units which I assume serve 3 different floors?0 -
Systems
They must be different properties. The first system is hot water, the second is steaam, and the third is a heat pump.0 -
I'd say
the two American-Standard hot-water boilers and the Bryant steamer date from the 1960s, when fuel was cheap and the only incentive was to make boilers as cheaply as possible.0
- 87.8K THE MAIN WALL
- 132 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
