Name That Boiler!!!
susie
susie Member Posts: 1
Can anyone identify any of these boilers, the year they were probably installed and their typical energy efficiency?!?!
I need to prove that I am increasing the efficiency of my rehab by 34% after installing new energy star equipment but I can't unless I know what the originals are...
Thanks!
  • Tim McElwain
    Tim McElwain Member Posts: 4,657
    Look on the
    rating plates for the Make, Model Number and Serial numbers. Also look for Input in BTU's and Output in BTU's.
    Has a heat loss been done on these units which I assume serve 3 different floors?
  • RobG
    RobG Member Posts: 1,844
    Systems
    They must be different properties. The first system is hot water, the second is steaam, and the third is a heat pump.
    Steamhead Member Posts: 18,054
    I'd say
    the two American-Standard hot-water boilers and the Bryant steamer date from the 1960s, when fuel was cheap and the only incentive was to make boilers as cheaply as possible.
    Consulting
