Tankless water heaters for hydronic slab heat
Carp
Member Posts: 6
I have always been warned not to use a tank-less water heater for hydronic heating systems. I am not sure why, but I have heeded the warning. I have a new contractor that wants to do this in a residential slab heat job. What are your thoughts please.
Thank you
Karl
Thank you
Karl
Keep looking
Find a new contractor.:NYplumber:0 -
tankless water.....
heaters are not designed to do this. Its sort of like using a Moped to travel from Boston to Buffalo on I-90. Will you get there...ya but it will not be a fun ride. It wil certainly not give you the most efficient fuel use.0 -
Thanks
Thanks guys. I just wanted to hear some input!0 -
Earlier Post
Here's an earlier post. If you do a site search, you'll find this has been thoroughly addressed here. Seems like this subject comes up almost weekly.
http://www.heatinghelp.com/forum-thread/142291/On-demand-water-heaters-for-small-heating-loads-pros-and-consBob Boan
You can choose to do what you want, but you cannot choose the consequences.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
