Can you identify this hydronic baseboard?
Does anyone recognize what brand of hydronic baseboard uses this bracket? Enclosure stands about 7-1/2" high, front panel is smooth, concave vane uses folded edge over round stamping on bracket for adjustment instead of separate slide-away swivel piece. I've found rather a lot of it installed in two apartments in Providence, RI, and in pretty good shape, but no trim pieces were ever used, and I think I could clean it up and make it look just fine with some correctly fitted corner and wall trims.
Thanks
Vbob
  • kcopp
    kcopp Member Posts: 4,682
    I'm going to....
    guess Suntemp.
  • Bob Vennerbeck
    Bob Vennerbeck Member Posts: 107
    I think we have a winna!
    Thanks! Ran with your hint and looked up Suntemp catalog online - they've made some 'improvements' since this vintage, but I bet the trim hasn't changed. Now to find someone with it in stock....
    Vbob
  • Harvey Ramer
    Harvey Ramer Member Posts: 2,289
    Don't know where you are at
    but Sommerville carries Suntemp.
  • Bob Vennerbeck
    Thos. Somerville Co. a bit out of range
    I see that the Thos. Somerville Co. of PA, MD, VA area carries Suntemp, but that's a bit out of my range from RI - or is there another Sommerville outfit I'm not finding?
    Thanks
    Vbob
  • Harvey Ramer
    I don't know
    If they go that far north or not. I think they do but not sure. They might ship to you if you call them and ask.
  • Bob Vennerbeck
    found a local distributor for Suntemp
    Thanks - I heard back from Suntemp Central, and they are distributed in RI by Sydney/Bell-Simons Supply, which is pretty close by.
    I'm still at the stage of 'buy one end cap and make sure it fits....'
    Thanks to all for help!
    Vbob
