Can you identify this hydronic baseboard?
Bob Vennerbeck
Member Posts: 107
Does anyone recognize what brand of hydronic baseboard uses this bracket? Enclosure stands about 7-1/2" high, front panel is smooth, concave vane uses folded edge over round stamping on bracket for adjustment instead of separate slide-away swivel piece. I've found rather a lot of it installed in two apartments in Providence, RI, and in pretty good shape, but no trim pieces were ever used, and I think I could clean it up and make it look just fine with some correctly fitted corner and wall trims.
Vbob
Vbob
I'm going to....
guess Suntemp.0 -
I think we have a winna!
Thanks! Ran with your hint and looked up Suntemp catalog online - they've made some 'improvements' since this vintage, but I bet the trim hasn't changed. Now to find someone with it in stock....
Vbob0 -
Don't know where you are at
but Sommerville carries Suntemp.0 -
Thos. Somerville Co. a bit out of range
I see that the Thos. Somerville Co. of PA, MD, VA area carries Suntemp, but that's a bit out of my range from RI - or is there another Sommerville outfit I'm not finding?
Vbob0 -
I don't know
If they go that far north or not. I think they do but not sure. They might ship to you if you call them and ask.0 -
found a local distributor for Suntemp
Thanks - I heard back from Suntemp Central, and they are distributed in RI by Sydney/Bell-Simons Supply, which is pretty close by.
I'm still at the stage of 'buy one end cap and make sure it fits....'
Thanks to all for help!
Vbob0
- 87K THE MAIN WALL
- 57 Biomass
- 111 Chimneys & Flues
- 5.7K Gas Heating
- 106 Geothermal
- 70 Pipe Deterioration
- 978 Plumbing
- 6.3K Radiant Heating
- 387 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
