Electric water conditioner.
Harvey Ramer
Member Posts: 2,281
I have a bathroom out in my garage that doesn't get used much. It used to be that the water in the toilet would get a film over the top if it was not flushed for a long time. I put an electric water conditioner in early this year and that problem disappeared. Now my question is, would this device have enough zapping power to acheive similiar results in an underground cistern that is used for domestic water. Cisterns can get pretty nasty.
You'd have to circulate...
Just having the conditioner installed on the incoming line is not adequate. These devices do have a finite expectancy to the treatment. If you were to circulate between the conditioner, and the cistern, and keep that water moving, then the water would be "conditioned".
But remember that they do nothing to the potability of the water. Won't make it better, but won't make it worse. You'd have t go to an ultraviolet conditioner to cover that, and then you will get other "issues" you hadn't expected (thinking growth of flora and fauna in the water due to the presence of UV light).
ME0 -
makes sense.
I suppose if the UV light were not placed in the circulated circuit but rather after the pressure tank it would probably avoid those issues. The water going into the cistern would be potable.0 -
makes sense.
aeration
have you considered aerating or perhaps even ozonating cistern ?0 -
You will have to explain.
Water conditioning is something i know little about.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
