steam heat professionals north of Boston?
Hi Everyone,
I have been in the process of renovating a house I bought several years ago.  It has the original Pierce Coal fired steam boiler that was converted for oil use way long ago.  The house is heated by one pipe steam that flows toTrane floor Convector units.
For the time I have been in the house, the boiler has run flawlessly; I can say the same for the system as a whole--no banging etc, spitting, etc.
Either this year or the next, I plan to replace the unit with a more efficient steam boiler that runs on natural gas to maybe take advantage of some of the rebates out there.
I'm looking for any professionals that are willing to come out, take a look, listen to my concerns and provide a detailed quote on the scope of work that would include assurances on adherence to manufacturer's near boiler piping requirements and a guarantee of the system functioning as it should.  I hope I am not expecting too much.  After reading Dan's books and lurking on this board for a few years, I'm taking his advice and being up front with my expectations.
Thanks in advance,
Steve
  • Rod
    Rod Posts: 2,067
    North of Boston?
    Hi- I guess the first thing that comes to mind is Where is "North of Boston"?
  • Steve Nichols
    Steve Nichols Member Posts: 124
    clarification
    Sorry, to be more specific I live in Danvers ("North Shore")
  • Rod
    Rod Posts: 2,067
    Boston Steam Pros
    Try the "Find a Contractor" section at the top of this page. Scroll down to the "States" section as the zip code section isn't reliable. While you maybe out side their normal service area, most steam pros will travel a bit for an installation so that should expand your choices.
    -Rod
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,422
    Yes I go there
    what do you need?
    cell # 413-841-6726
  • Steve Nichols
    boiler replacement and system evaluation
    Hi Charlie,
    I'm looking to replace an old steam boiler and upgrade to a high efficiency gas fired unit.  The information at the top of the thread should give you a rough idea of what I am looking for.  I'd be happy to give you a call and provide additional information.  Just let me know what times are okay to call and if the contact number listed on heatinghelp is the one I should use.
    Thanks,
    You can reach me there or
    call my cell # @ 413-841-6726. after 8 am and before 9 pm is best. If I can talk I will be happy to answer your questions, if not I will call you back when I have more time to talk.
    cell # 413-841-6726
