steam heat professionals north of Boston?
Steve Nichols
Member Posts: 124
Hi Everyone,
I have been in the process of renovating a house I bought several years ago. It has the original Pierce Coal fired steam boiler that was converted for oil use way long ago. The house is heated by one pipe steam that flows toTrane floor Convector units.
For the time I have been in the house, the boiler has run flawlessly; I can say the same for the system as a whole--no banging etc, spitting, etc.
Either this year or the next, I plan to replace the unit with a more efficient steam boiler that runs on natural gas to maybe take advantage of some of the rebates out there.
I'm looking for any professionals that are willing to come out, take a look, listen to my concerns and provide a detailed quote on the scope of work that would include assurances on adherence to manufacturer's near boiler piping requirements and a guarantee of the system functioning as it should. I hope I am not expecting too much. After reading Dan's books and lurking on this board for a few years, I'm taking his advice and being up front with my expectations.
Thanks in advance,
Steve
Thanks in advance,
Steve
North of Boston?
Hi- I guess the first thing that comes to mind is Where is "North of Boston"?0 -
clarification
Sorry, to be more specific I live in Danvers ("North Shore")There was an error rendering this rich post.
Boston Steam Pros
Try the "Find a Contractor" section at the top of this page. Scroll down to the "States" section as the zip code section isn't reliable. While you maybe out side their normal service area, most steam pros will travel a bit for an installation so that should expand your choices.
-Rod0 -
Yes I go there
what do you need?Cost is what you spend , value is what you get.
cell # 413-841-6726
boiler replacement and system evaluation
Hi Charlie,
I'm looking to replace an old steam boiler and upgrade to a high efficiency gas fired unit. The information at the top of the thread should give you a rough idea of what I am looking for. I'd be happy to give you a call and provide additional information. Just let me know what times are okay to call and if the contact number listed on heatinghelp is the one I should use.
Thanks,There was an error rendering this rich post.
You can reach me there or
call my cell # @ 413-841-6726. after 8 am and before 9 pm is best. If I can talk I will be happy to answer your questions, if not I will call you back when I have more time to talk.Cost is what you spend , value is what you get.
cell # 413-841-6726
- 85.9K THE MAIN WALL
- 52 Biomass
- 420 Carbon Monoxide Awareness
- 79 Chimneys & Flues
- 5.3K Gas Heating
- 94 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 886 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.6K Strictly Steam
- 51 Water Quality
- 41 Industry Classes
- 17 Recall Announcements
