If our community has helped you, please consider making a contribution to support this website.  Thanks!
recovery bottles
                    Paul_69
                    Member Posts: 251
                    how many recovery bottles should you have with a recovery machine?i have one for r22 and one for 410a. what about holding different both good freons to put back in system and what about contaminated freons?do you need 4 bottles? or can you mix r22 and 410a for disposal and just need 3 bottles?  thx
            Recovery Bottles
I keep 3 on the service truck. One for 22 and 410a, whenever i recover a burnout I turn in the third tank for recycling right away. We have a free exchange/tank swap program in our region.0 -
            Never Mix
Never ever mix refrigerants in a cylinder. We keep 1- 50# for 22. 1- 50# for 410. 1-30# for odd refrigerants (usually small systems for process refrigeration) these get turned in pretty quickly. If it is a burnout, we also turn that cylinder in soon too. My chiller techs keep several 50's on their vans. They deal with R-407 quite a bit on mid 2000's air cooled McQuay chillers.0 -
            recovery bottles
thx for replys guys! could you carry 1 for 410a and 1 for r22 for holding freon while doing repairs and then put this good freon back in system and then if you get a burn out just put it in the correct bottle and recycle it right away so you dont have to carry 3 bottles? i work only with these 2 refegerants...thankyou0 -
            Kinda
As long as the two refrigerants never hit the same cylinder. Once a cylinder has had either refrigerant in it, you can't put the other in. So one cylinder would be R410A only and one would be R22 only. Then if you get a burnout, turn it in for exchange.0 -
            bottles
thx meplumber.on a burnout do you mean recycle or exchange for a new bottle. the place i deal with recycles my bottles that i bought from them. i didnt know anything about exchanging bottles.i always get same bottle back after they suck it out.0 -
            exchange
We have an exchange program. We turn in a cylinder with the appropriate documentation and we get a new empty one.0
 - 87.2K THE MAIN WALL
 - 118 Chimneys & Flues
 - 113 Geothermal
 - 164 Indoor-Air Quality
 - 73 Pipe Deterioration
 - 6.4K Radiant Heating
 - 393 Solar
 - 15.5K Strictly Steam
