Can a oil burner pump be used for water?
LarryC
Member Posts: 330
Wallies,
I have been searching on the Wall and I am not sure if I can do what I want to do. I am looking for a small pump for a project. I am looking at recirculating water at about 60 psi and at a flow rate of under 2 gallons per hour. I thought of using the oil pump in an oil burner and drive it with a suitable DC motor.
A couple of questions.
1) Are oil burner pumps centrifigal or gear pumps?
2) Are they compatable with water? If not, can they be made to be?
My thought is to search the local scrap yard for discarded burners and scavenge what I need. Are there specific models or brands I would need to look for?
Thanks.
Larry C
Thanks.
Larry C
oil pump
Yes it will pump water for a few minutes and then it will rust up and sieze.0 -
try a carbonator pump
ought to be a few of those in the boneyard, or perhaps a used restaurant supply.0 -
Water Pumps:
I'd be looking at an aquarium pump before any of those. They're cheap.0 -
aquarium pump?
I have a dinky aquarium pump to bubble a small stream of air into a tube carrying essentially zero-pressure water. It is a diaphragm pump. I do not know that it would be even strong enough to pump water, and I have no idea of how long the diaphragm would last if water got into it.
Is there a different kind of aquarium pump that you have in mind? One designed to pump water?0 -
pump pressure
It occurs to me this is an open-ended problem statement. Are you recirculating the water in a closed loop with a static pressure of 60 PSI, or do you need 60 PSI just to overcome the friction head in the loop? If the former, what is the friction head of the system?0 -
More details
What I am working on is a table top EDM (Electrical Discharge Machining) machine. I am looking to recirculate a fluid thru a hollow electrode. The fluid will flush the tiny metal fragments out of the hole in the work piece. As I understand it, I will need a relatively high pressure (60 psi?) but low flow rate. Initially I am looking at water as my dielectric fluid, but it might change to an oil of some sort, perhaps something similar to kerosene.
Other people have mentioned using positive displacement pumps for this, and so I thought a source for an inexpensive low flow positive displacement pump would be an oil burner carcass. Gear pumps also have the advantage that I can easily change the flow rate by varying the pump speed.
The setup would be taking a suction from a open tank. Pumping thru the electrode, collecting the runoff in a settling tank where most of the heavy particles fall out, and letting it overflow back into the main tank. Smallest electrode will probably have an ID of around .040 to .060 inches. Pressure and flow would be regulated by pump speed and perhaps a needle valve teed off the discharge line before the electrode.
So ...
1) Am I on the right track or not?
2) Will water destroy the pump immediately or will it take a significant period of time?
3) Could I store oil in the pump between uses to extend its life? I am OK with the idea of having a layer of oil floating on the water in the main tank.
4) Do you foresee seal or bearing problems?
I appreciate all advice you folks are willing to throw my way.
Thanks,
Larry C0 -
Gear pumps
Look at Teel gear pumps at W.W.GraingerThere was an error rendering this rich post.
Try
Micropump on eBay0 -
Fluid-O-Tech
TMSR and TMFR pumps have EC motors, are seal-less, and include control inputs.
http://www.fluidotech.it/Contents/Documents/TMFR%20pump-motor%20unit%20with%20a%20magnetic%20drive%20rotary%20vane%20pump%20in%20brass%20and%20stainless%20steel.pdf0 -
Beautiful pumps but a bit overkill for my application
SWEI,
The Fluid-O-Tech units are beautiful units but they are overkill for my application. I am looking only for 2 gallons an HOUR and price is a significant issue. That is why I am looking at salvaging oil burner pumps.
What other equipment uses low flow with moderate pressure, pumps?0 -
in that case
Rather than trying to vari-speed the motor, you might want to look at using some kind of PRV to dump excess pressure (bypass the closed loop and return to a supply tank.)0 -
Any guesstimates on how long it takes to rust?
Any guesstimates on how long it will take for the oil burner gear pump to rust after using it for water?
Do all Becket and Riello residential burners use gear pumps?
Thanks.0 -
oil burner pump
I wouldnt think that an oil burner pump would live even a few hours unless you are pumping some sort of oil. The pumped media is the lubricant for the gear rotors.0 -
lots of pd pumps for water
both gear & vane. Use a pulley to get the flow rate you want and a relief valve to limit pressure. try www.proconpumps.com/0 -
If
it is a Kero pump, it might work. we had lubrication issues years ago with Kero only units, and would replace the fuel pumps with one built for Kero. Check with Sids?0 -
you might also look ...
... at peristaltic pumps. They don't much care what fluid you pump as long as the right tubing is used.
Yours, Larry0 -
paddle pump
this is a nicer version of those drill motor paddle pumps. This will do 60 psi at about 3 gpm with a higher speed drill motor.
hrBob "hot rod" Rohr
Living the hydronic dream0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 983 Plumbing
- 389 Solar
