Navien Combo
jackie c
Member Posts: 7
in Gas Heating
Hi,I was just wondering how to calculate the fresh air and flue heights
for the com bi units.Somebody told me i had to log on some website for
snowfall heights etc,Thanks
I assume what you
are looking for is the termination of the flue exhaust and the fresh air intake for your unit? The snow fall thing is designed to insure the exhaust and intake are above the average snowfall for your area.
If you are a homeowner then your installer should handle that for you. If you are a contractor check with your local weather bureau.0 -
Navien Combo
Thanks Tim.0 -
make sure
Like Tim said, that is, the installers responsibility...I will also add this, confirm with the manufacture they allow snorkel kits, if needed,some do, some don't...You may not like the looks...Finding the proper vent location is very important...Ja0
