Navien Combo
jackie c
jackie c Member Posts: 7
Hi,I was just wondering how to calculate the fresh air and flue heights
for the com bi units.Somebody told me i had to log on some website for
 snowfall heights etc,Thanks
  • Tim McElwain
    Tim McElwain Member Posts: 4,657
    I assume what you
    are looking for is the termination of the flue exhaust and the fresh air intake for your unit? The snow fall thing is designed to insure the exhaust and intake are above the average snowfall for your area.
    If you are a homeowner then your installer should handle that for you. If you are a contractor check with your local weather bureau.
  • jackie c
    Navien Combo
    Thanks Tim.
  • j a_2
    j a_2 Member Posts: 1,804
    make sure
    Like Tim said, that is, the installers responsibility...I will also add this, confirm with the manufacture they allow snorkel kits, if needed,some do, some don't...You may not like the looks...Finding the proper vent location is very important...Ja
