Copper Flue piping
ScottMP
Member Posts: 5,882
This flue piping was connected to the old boiler we removed. Look at the talent that went into producing this.
" Oh yes sir, we remove all the old materials" :)
Can it be used with modcon equipment?
Might be cheaper than Centrotherm... ;-)
Can't say I've ever seen copper used as an exhaust vent.
ME0 -
Copper Flue
This is a new one to me!
Seems like the hot flue gases would have discolored it more than they did.0 -
Scott....
did you buy everyone lunch???
Copper venting
I have seen some copper venting in Europe on fireplaces! I have also seen copper condensate drains from vents beign destroyed within 6 moths!
Henry0 -
These had to be about 45 yeasr old.
The hot water heater vents are still operating.
Here's the boiler this flue came off. We installed a Buders atmosperic natural gas boiler. The elderly owner didn't see his chance of getting a ROI in his life time. He's probably correct.0 -
tough choice
I've never seen that before. Almost a toss up whether to bring it to the scrap yard, or hang it on the shop wall for posterity!0 -
Cash won
I know what you mean though.0 -
York "Heat Pipe" Furnace
Does anyone remember the York Heat Pipe furnace from back in the mid '80's and all the problems it had? It used a copper coil in coil for the heat ex. and was about 85% efficient.
The flue and the heat ex. would rot out in short time.
Another "innovation" that looked good in the lab, but failed miserably in the field.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
