Copper Flue piping
ScottMP
ScottMP Member Posts: 5,882
This flue piping was connected to the old boiler we removed. Look at the talent that went into producing this.
" Oh yes sir, we remove all the old materials"  :)
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,875
    Can it be used with modcon equipment?
    Might be cheaper than Centrotherm... ;-)
    Can't say I've ever seen copper used as an exhaust vent.
    ME
  • Charles Johnson
    Charles Johnson Member Posts: 24
    Copper Flue
    This is a new one to me!
    Seems like the hot flue gases would have discolored it more than they did.
  • STEVEusaPA
    Scott....
    did you buy everyone lunch???  :)
  • Henry
    Henry Member Posts: 998
    Copper venting
    I have seen some copper venting in Europe on fireplaces! I have also seen copper condensate drains from vents beign destroyed within 6 moths!
    Henry
  • ScottMP
    These had to be about 45 yeasr old.
    The hot water heater vents are still operating.
    Here's the boiler this flue came off. We installed a Buders atmosperic natural gas boiler. The elderly owner didn't see his chance of getting a ROI in his life time. He's probably correct.
  • Paul Fredricks_3
    Paul Fredricks_3 Member Posts: 1,556
    tough choice
    I've never seen that before. Almost a toss up whether to bring it to the scrap yard, or hang it on the shop wall for posterity!
  • ScottMP
    Cash won
    I know what you mean though.
  • Ironman
    Ironman Member Posts: 7,908
    York "Heat Pipe" Furnace
    Does anyone remember the York Heat Pipe furnace from back in the mid '80's and all the problems it had? It used a copper coil in coil for the heat ex. and was about 85% efficient.
    The flue and the heat ex. would rot out in short time.
    Another "innovation" that looked good in the lab, but failed miserably in the field.
    Bob Boan
